Re: Iiiiiiiiirrrrrkk!
Posted: Wed Apr 16, 2003 7:20 am
by johneroberts
Sounds like air in take problem of some kind,or noisy DVs, this does effect the performance quiet dramatically though, check all your hoses and linkages, for splits or decouplement.
Jr
Posted: Wed Apr 16, 2003 7:22 am
by johneroberts
Also first sign of Turbo failure is a real bad nose [img]images/graemlins/frown.gif[/img]
But to be safe get it checked ASAP
Good luck
jr
Posted: Wed Apr 16, 2003 2:15 pm
by charlesdash
Check some of Mark W's posts from RS4.org, (they are here somewhere I think.) Sounds quite similar to his problem with a loose hose on a turbo. His got worse until he really started to lose power.
Posted: Wed Apr 16, 2003 4:38 pm
by Alan
Is it an "increasing" whistling type noise?
If so this can definitely point to imminent turbo failure [img]images/graemlins/033102bad_1_prv.gif[/img]
Definitely get it looked at ASAP.
A split/badly connected hose etc. should lead to a noticeable drop in performance, particularly if it's serious enough for the sound to be heard inside the car!
Hope it doesn't prove to be serious...good luck!
Posted: Fri Apr 18, 2003 4:16 am
by Michael
no that I'll ever claim to know a hell of a lot I have had turbo hose failure in the RS. Was after I changed my dump valves to Forge. Noticed a huge drop in power but no change in engine/turbo noise. So going from that narrow piece in info to me sounds like it's posibly a problem with a turbo itself. A 'whistle' however- I've always had that at low power- i.e. 1,5000rpm to 2,800.
