Maximum power on standard MAF?
Posted: Fri Feb 22, 2013 8:21 am
by DamoM
I have heard mixed views on what the limitation of the standard MAF is. My car was on 592bhp and have upgraded all internals and put matched 2.4 heads on. Some say that the MAF cannot read glow above these kind of numbers?
Re: Maximum power on standard MAF?
Posted: Sat Mar 01, 2014 9:34 am
by Speedr8
maximum throughput 550 g / s
Tom
Posted: Tue Mar 25, 2014 1:58 pm
by Nobby
I'm surprised no-one has developed a big MAF conversion. Same sensor into a slight bigger housing and it will move spread the range it can read. Needs to be carefully calculated though as you'd need a big remap to account for the difference.
Posted: Tue Mar 25, 2014 2:25 pm
by bam_bam
Nobby wrote:I'm surprised no-one has developed a big MAF conversion. Same sensor into a slight bigger housing and it will move spread the range it can read. Needs to be carefully calculated though as you'd need a big remap to account for the difference.
You mean like the 100mm hitachi MAF housing Doug put in his B5 WB? It took a long time to get that map right, 3 days IIRC.
Posted: Tue Mar 25, 2014 2:51 pm
by Nobby
Still might be quicker (and cheaper) that getting a MOTEC. Plus keeps all the standard ECU feastures.
Posted: Tue Mar 25, 2014 3:16 pm
by bam_bam
MoTek is said to be a pig to get working on VAG.
Posted: Tue Mar 25, 2014 4:40 pm
by S4Player
Motec is a bitch to map. Bigger maf's been around for years my b5 was mapped on 100mm maf 4 years ago
