RNS-E retrofit issues RS4 B5
Posted: Fri Nov 02, 2012 3:44 pm
by >RS4<
Hi Guys I have some troubles getting my RNS-E to work properly in my RS4 B5, i was kinda hoping you could help me out here...
I know this has been done a lot of times with some slight things that don't work 100% like the "clock issue" but my retrofit doesn't seem to work ok at all.
I got the plug and play harness from ebay and bridged the can signals @ the TMC box under the dash,so far so good.
Next thing i did was coding the RNS-E expecting it to work ok, but no luck.
The RNS-E doesn't start up but I hear it trying to,now when i remove the plug which contains the can signals and I press the on-off swich it start up without asking for a code with a very faint sound from the front left speaker,after it has started up and I reconnect the can signal plug it seems to work ok.
If i switch on the lights of the car , the lights of the RNS-E do not light up.
Also the RNS-E doesnt react to the ignition on of off...
Does anybody recognise these "symptoms" ?
I would really like to get it to work properly.
TIA for the input.
Posted: Sun Nov 04, 2012 12:41 pm
by MrGeneric
Your best bet is to post this on audisrs! Alot of b5 enthusiasts there!!!
Re: RNS-E retrofit issues RS4 B5
Posted: Mon Dec 03, 2012 6:24 pm
by RS4KILLA
have you used the cangate module?
Posted: Wed Mar 13, 2013 11:20 pm
by volkscraft
I have an RNS-e in mine, does the ebay lead you bought support Bose? if not that may cause your sound problem. I have taken my CAN from the Dash pod. Also if you get the Code bouncing issue, you can enter the code with ignition off, turn ignition on then carry out a soft reset. Should be ok after that.
Clock issues are rectified with a Can gate module, you'll need to contact Bjarne in the USA for one of these.
