Hi,R1RS4 wrote:Hi there HEKTORHEKTOR wrote:To run a 380mm disc using b7/c5 calipers all that is needed is a 2x 7mm spacers per caliper fitted between the caliper & caliper bracket.
I have recently fitted girodisc 380mmx34mm discs to my b5 rs4.
Ok, do you know if the hole centres on the B5 bells are the same as on the B7?
How much did the discs set you back?
Are they drilled and vented?
What's the weight comparison?
Do you have a link for the discs?
cheeRS R
B7 discs fit a b5 without modification. Centre bore being 57.1mm
more information can be found here - http://audisrs.com/about53168.html
