Question: Do the B7 19" 9J ET29 wheels fit onto a B5?
2.7 V6 30v biturbo - 380 bhp
JesseJonesJackson
Post by JesseJonesJackson » Sun Sep 26, 2010 8:37 am
I'm talking RS4's here
....if so can or should you run spacers?
...if so what width?
...is there anything else I should be aware of?
TVM...JJJ
RS4 B5 Black - MRC Custom Map, full Milltek system and downpipes, H&R ARB
boxerdogted
RE: Question: Do the B7 19" 9J ET29 wheels fit onto a B
Post by boxerdogted » Sun Sep 26, 2010 8:45 am
I'm running B7 RS4 wheels with 15mm Eibach Spacers and 275/30/19 Goodyear Asym tyres.
HTH
2001 RS4 Misano Red
jimbo1234567
Post by jimbo1234567 » Sun Sep 26, 2010 10:19 am
you dont need spacers , they will fit fine without but its what you like the look of the best. an 8mm spacer will bring the et back to 20 from 28 but in my experience having the wheels stuck out just rashes the side of the car with stonechips. also remember that the b7 wheel is half an inch wider than a b5 one so with a 20mm et the wheel will already be 1/4 inch further out than a std wheel
boxerdogted
Re: RE: Question: Do the B7 19" 9J ET29 wheels fit onto
Post by boxerdogted » Sun Sep 26, 2010 11:19 am
jimbo1234567 wrote:you dont need spacers , they will fit fine without but its what you like the look of the best. an 8mm spacer will bring the et back to 20 from 28 but in my experience having the wheels stuck out just rashes the side of the car with stonechips. also remember that the b7 wheel is half an inch wider than a b5 one so with a 20mm et the wheel will already be 1/4 inch further out than a std wheel
It depends on what size tyres you use as to wether you need spacers, the fronts are not a problem but the rears are, 265/35/19 touch the rear suspension upright, 275/30/19 Goodyears clear by about 1mm which is to close in my opinion, you could just use an 8 or 10mm spacer on the rear.
As Jimbo said it depends what you like the look of.
2001 RS4 Misano Red
JesseJonesJackson
RE: Re: RE: Question: Do the B7 19" 9J ET29 wheels fit
Post by JesseJonesJackson » Sun Sep 26, 2010 3:29 pm
....So if I understand you correctly:
a 275/30/19 with an 8/10mm spacer will clear the suspension and miss the arch?
Whats the standard tyre size for the B7 RS4?
boxerdogted
Post by boxerdogted » Sun Sep 26, 2010 5:05 pm
Std tyre size for B7 RS4 is 265/35/19.
They will clear the arch no problem as i run 15mm Hubcentric spacers and no rubbing.
275/30/19 Tyres are also cheaper than 265/30/19.
2001 RS4 Misano Red
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Thu Sep 30, 2010 9:05 pm
255/35/19 is the standard tyre size used on the B7
You can usee anything from a 255/30 up to a 275/30/19 tyre on the B5.
With a 265 or 275 you will need to run spacers as the tyre fouls the rear suspension arm
If you use a 255/30, you don't need to run spacers, as the less width clears the suspension arm
Bear in mind not all tyre sizes are the same width, from make to make
Virdee Autos ~ 07950-526592
jimbo1234567
Post by jimbo1234567 » Fri Oct 01, 2010 1:06 pm
i have my 9.5 x 19 et 30 bimotos on with 275 30 assymetrics and no spacers, the wheels sit nicely in the arch and theres no rubbing front or back, these same wheels with 10mm spacers stuck out too much for me.
beastman
Re: RE: Re: RE: Question: Do the B7 19" 9J ET29 wheels
Post by beastman » Fri Oct 01, 2010 4:23 pm
jimbo1234567 wrote:i have my 9.5 x 19 et 30 bimotos on with 275 30 assymetrics and no spacers, the wheels sit nicely in the arch and theres no rubbing front or back, these same wheels with 10mm spacers stuck out too much for me.
do you have standard suspension? I run these wheels with 10mm as felt suspension arm was too close so bought spacers. Guy I bought from had no spacers but ran coil overs.
Diesel, fuel of the devil!
RSTaSIS4
RE: Re: RE: Re: RE: Question: Do the B7 19" 9J ET29 whe
Post by RSTaSIS4 » Wed Oct 06, 2010 3:11 am
I am currently running 18x10 all around with ET20 on coilovers, and do not have any issue with rubbing whatsoever.. Tires i am on 255/35/18..
kiwi_rs4
Post by kiwi_rs4 » Wed Oct 06, 2010 9:33 am
^^What wheels do you have?
RSTaSIS4
Post by RSTaSIS4 » Wed Oct 06, 2010 9:40 am
kiwi_rs4 wrote:^^What wheels do you have?
I am Running on BBS LM
jimbo1234567
Post by jimbo1234567 » Thu Oct 07, 2010 10:30 am
yes stock suspension, coilovers dont make any difference as its the cast iron arm that fouls the tyre, i modified mine to give another 3mm although the tyre didnt touch it was very close. the other alternative is to use 3mm spacers which will give you some more clearance but still allow the spigot to locate keeping the wheel centered.
JesseJonesJackson
Post by JesseJonesJackson » Sun Oct 10, 2010 9:36 am
Right...sounds like there are various configs that will work on the B5.
I could run the following tyres on the B7 wheels with the ET29 offset:
1) 255/35/19 with a 10mm spacers
2) 265/30/19 with a 10mm spacer
3) 255/30/19 without any spacers
4) 275/30/19 with a 10mm spacers
Correct?
Imola
Post by Imola » Tue Oct 26, 2010 10:03 pm
any pics of this combination (B7 wheels on a B5!)
Users browsing this forum: No registered users and 40 guests
