Hi folks!
I have noticed that my cooling fan comes on when i start the car and stays on until i turn off the ignition, regardless of weather. Also, i am losing boost occasionally. The dealer fitted a new coolant temp' sensor recently but that aint cured it. I have also fitted new EGT's, an new MAF and new diversion valves. My air con isn't working the best, could this be connected?? I have had the car VAG Com'd and that shows only one fault...over fueling on boost.
I'm starting to pull my hair out a bit as this is costing a small fortune and isn't curing the problem.
Any input would be appreciated.
Cheers.
Cooling Fan
RE: Cooling Fan
There a few different coolant temp sensors. Which one did you have changed? There will probably be some sort of thermal switch for the fan.
Imol4vant
RS4 B5
RS4 B5-
Steviescottish
