Alignment?
2.7 V6 30v biturbo - 380 bhp
Emp2k
Alignment?
Post by Emp2k » Sat Jul 03, 2010 11:46 am
Hello.
My Rs4 is feeling a bit nervous at the rear at higher speeds.
Thinking about doing a 4wheel alignment.
What do you guys run and what is the stock numbers?
rhunter203
RE: Alignment?
Post by rhunter203 » Sat Jul 03, 2010 7:04 pm
I had this problem. I changed the suspension then had the car realigned. Expensive but worth it!
MRC 490BHP 500ft/lbs RS4
3.6 0-60 12.04 1/4M
Emp2k
Re: RE: Alignment?
Post by Emp2k » Sat Jul 03, 2010 11:54 pm
rhunter203 wrote:I had this problem. I changed the suspension then had the car realigned. Expensive but worth it!
Hummm yea. Im poundering though if its just the RS4 chassi setup that does it or if its my alignment.
My car has only done 112 000 miles so dampers and the like should be fresh and i cant feel any issues either regarding thoose. Thinking about starting with H&R springs and alignment fpr the moment. What you guys think?
lengster1
RE: Re: RE: Alignment?
Post by lengster1 » Sun Jul 04, 2010 10:29 am
I would look at suspension bushes etc mine had all replaced when only 4 years old,they are prone to wearing them out with the high torque surge when boost kicks in.112000miles on origonal shocks would be far from fresh imo but these are things that degrade very slowly and only when you drive a younger or lower mileage example you feel the difference,i suffered the same feeling from the rear of the car if i hit a manhole cover mid cover etc
Emp2k
Post by Emp2k » Sun Jul 04, 2010 11:25 am
I driva an example with 192k miles on the clock and that didnt have this issue so i pretty much ruled that one out. Might have to reconsider that one then. Thanks :)
Dosent anyone hade alignment specs?
simplysimon
tracking
Post by simplysimon » Sun Jul 18, 2010 11:17 pm
my rs4s only done 54k , it was twitchy when i got it- have had a laser alignment ( a good centre should have the right settings for your car in the computer ) and its made a HUGE difference - for the 160 quid it cost me including replacing a seized front linkage it was well worth it. with 460 brake i want to know all the wheels are pointing in the same direction!
It may not directly solve your problem but its worth getting it done anyway.
good luck, Si
Rs4Fan
Re: Alignment?
Post by Rs4Fan » Sun Jul 18, 2010 11:38 pm
Emp2k wrote:Hello.
Have a look st the suspension bushes before you do anything expensive. They might just need replacing.
'00 S4 (sold)
'01 RS4 (sold)
'93 964RSA
'94 964 Turbo
'08 E63 AMG
'10 Cayenne GTS
jc..
RE: Re: Alignment?
Post by jc.. » Wed Jul 21, 2010 7:12 pm
no point re-aligning suspension on 100k bushes in my opinion.
line them up perfectly at standstill then watch them move by 2deg under load!
Emp2k
RE: Re: Alignment?
Post by Emp2k » Mon Sep 06, 2010 12:25 pm
Tried realignment and yes jc is correct when will i learn to listen :roll:
So what is the best option then. Just new uprated control arms or thoose adjustable ones? Does any1 here run these and what do they think?
Contigo
RE: Re: Alignment?
Post by Contigo » Mon Sep 06, 2010 7:02 pm
Just had my rear coil springs replaced and the car is tigher than a nuns asshole now!
2001 Avus Silver RS4 B5 60k on clock, MRC Custom Remap, Sunroof, Bluetooth prep
2006 Daytona Grey RS4 B7, RNS-E - SOLD
2006 BMW M6 - GONE
TimN
RE: Re: Alignment?
Post by TimN » Mon Sep 06, 2010 8:25 pm
New rear springs are good, H&R ARBs even better!
Users browsing this forum: No registered users and 26 guests
