azr and asj- how do you tell
its probally really obvious but im new to the rs world if you hadnt guessed- how do you tell which lump you have and what is the difference!?
merry xmas and thanks
RE: azr and asj- how do you tell
ASJ engine only has 2 lambda probes and no SAI
ASJ = EU2 compliant
AZR engine has 4 lamda probes and SAI system
AZR = EU3 compliant
SAI = Secondary Air Injection system
I think the engine code is part of the V5 IIRC.
ASJ = EU2 compliant
AZR = EU3 compliant
- Virdee Autos
- Trader (Expired)
Engine code will also be in the service book (inside cover), and the other data sticker in the boot.
Will also be on the timing betl cover (LHS) IIRC
Virdee Autos ~ 07950-526592
It's also stamped on the front of the left head ..
Unit 20
0151 3366888
0151 3366888
Re: RE: azr and asj- how do you tell
Unfortunately that's wrongTopBear wrote:ASJ engine only has 2 lambda probes and no SAI
ASJ = EU2 compliant
AZR = EU3 compliant
Both engines have SAI and 4 lambda probes, the difference is that an ASJ ECU doesn't care about SAI or the post-cat lambdas, whereas the AZR one does, because of the EU3 emission norm.
S2tuner wrote:Unfortunately that's wrongTopBear wrote:ASJ engine only has 2 lambda probes and no SAI
ASJ = EU2 compliant
AZR = EU3 compliant
That's concerning as the lambda\SAI information was lifted from Elsawin v3.6
Users browsing this forum: No registered users and 40 guests
