How do i remove front bumper on a RS4 B5?
Does someone know how to remove the front bumper of an RS4 B5?
- Virdee Autos
- Trader (Expired)
RE: How do i remove front bumper on a RS4 B5?
Remove 3 Torx bolts on either arch liner.
Remove 2 alan bolts holding the bumper to the wing on each side
Remove engine belly pan, or if you don't have access to a ramp, then just unscrew the 3/4 screws holding the belly pan to the bumper
Remove front fog lamp grilles. Undo 6mm(?) alan bolts holding bumper to the bumper shocks/reinforcement.
Disconnect fog lamp wiring, and headlamp washer hose.
I think thats about it!
HTH
HTH
Virdee Autos ~ 07950-526592
Re: RE: How do i remove front bumper on a RS4 B5?
Virdee Autos wrote:Remove 3 Torx bolts on either arch liner.
HTH
do you have any pics of it?
- Virdee Autos
- Trader (Expired)
RE: Re: RE: How do i remove front bumper on a RS4 B5?
Unfortunately not
But all will become clear.
Re: RE: Re: RE: How do i remove front bumper on a RS4 B5?
Okey thanks alot anyway, ill try to get it down tomorrow.Virdee Autos wrote:Unfortunately not
RE: Re: RE: Re: RE: How do i remove front bumper on a RS4 B5
This might help (RS4 Self Study Guide from the "downloads" area of this site).
http://rs246.com/downloads/AudiRS4B5/Do ... 0Guide.pdf
Thanks for that one, does somone has the workshop manual? because this one reffers to the workshop manual sometimes.
i tok it down this morning it was pretty easy, when you had the right tools and you explaination.Virdee Autos wrote:Remove 3 Torx bolts on either arch liner.
HTH
Thanks alot.
- Virdee Autos
- Trader (Expired)
No problems, glad to be of help!
- mikeyquattro
- Top Gear
What else is involed to get the front end in the service position?
Tomorrow is another day
Not much, just unbolt the bumber supports and the bolts that hold the radiator frame in place.
Then you can pull the frame forward. You can use the long bumper bolts in the bumper supports bolt place to hold the frame up.
