Beeping (not 4 beeps) as I drive
2.7 V6 30v biturbo - 380 bhp
ptkend
Post by ptkend » Thu Mar 08, 2007 2:36 pm
Every now and then the car starts beeping at me, 1 beep every 10 seconds or so. No warning lights come on, and I get an OK when I start up. It eventually goes away, although last week it went on for around 5 minutes. Anyone any ideas ?
ScottyBoy
Post by ScottyBoy » Thu Mar 08, 2007 2:50 pm
What did you do marry it, sounds like my wife :lol:
Black 51 RS4 **Sold**
MRC Stage 2+Custom Re-Map
Gutted Pre-cats + RS6 Clprs B7 Discs
Milltek exhaust Fats 3.3
Now its the Grim Reaper, if you feel a tap on your rear quarter its time..................to get out of the way.
Marlon
Post by Marlon » Thu Mar 08, 2007 4:49 pm
I had this the other week on a long journey, did it cut the radio off as well?
I thinks its a warning for when you've been driving for over 2 hours continuously???? i never looked it up though......
2000 - Avus RS4
david7m
Post by david7m » Thu Mar 08, 2007 6:12 pm
In my car (S3) the DIS flashes (no beeps) when I have done 2 hours driving without the engine being turned off for more than 10 mins.
APR 270bhp S3, Mixer K6 750
Cheap performance tip - lie the rear seats flat Image
ScottyBoy
Post by ScottyBoy » Thu Mar 08, 2007 7:03 pm
Have you had a good look in the manual, there are lots of little settings that you can do with the car that sometimes you dont even know youve done eg. yesterday i set some speed thingy it came up as a circle with the number 1 and mph in it and that kept beeping.
dace
Post by dace » Thu Mar 08, 2007 8:35 pm
Try turning the TP button off on the stereo. I had this and it was a build up of traffic messages in the memory.
ptkend
Post by ptkend » Fri Mar 09, 2007 10:38 am
It's not to do with the radio (I turned that off) and it's not to do with speed limits (that shows up on the DIS). It might be to do with oil pressure as I've noticed it takes a while to lift off 60, longer than it used to. But if it was low oil I would have thought the DIS would have said something.
Any more ideas ? Thanks in advance.
Norrs2
Re: Beeping (not 4 beeps) as I drive
Post by Norrs2 » Fri Mar 09, 2007 12:37 pm
ptkend wrote:It's not to do with the radio (I turned that off) and it's not to do with speed limits (that shows up on the DIS). It might be to do with oil pressure as I've noticed it takes a while to lift off 60, longer than it used to. But if it was low oil I would have thought the DIS would have said something.
Oil Pressure????? That's your Oil Temperature Gauge surely!!!!
david7m
RE: Re: Beeping (not 4 beeps) as I drive
Post by david7m » Fri Mar 09, 2007 12:39 pm
You could always check your oil level using the old fashioned dip stick approach ;)
ptkend
Post by ptkend » Fri Mar 09, 2007 1:48 pm
Pressure, temperature, whatever. I know my Boyle's law ;-). The fact is, I know it's not to do with the oil (I have now checked).
So no-one knows what this could be ?
dace
RE: Beeping (not 4 beeps) as I drive
Post by dace » Fri Mar 09, 2007 4:36 pm
Have you tried the TP button on the radio? Mine was also turned off but I had to clear the memory......I think!!
chalky
Post by chalky » Fri Mar 09, 2007 7:27 pm
Yes,
Its been said already, if it was on a long run its the warning telling you to take a break, it should say 2H in the dash to say you have been driving 2 hours.
If you dont stop or leave the ignition running on short journeys it still counts up.
_______________________________________
2001 Misano RS4
