s4/rs4 manifolds
2.7 V6 30v biturbo - 380 bhp
Ryan_s3
s4/rs4 manifolds
Post by Ryan_s3 » Tue Jan 02, 2007 8:21 pm
Are s4 and rs4 exhaust manifolds the same?
Q for mrc/minhea, can the tubular manifold you sell fit the rs4 and can it be made with different flanges for fitment with other makes of turbo,ie t25/ihi etc?
thanks.
Image360bhp 342lb/t
MarkB
RE: s4/rs4 manifolds
Post by MarkB » Tue Jan 02, 2007 9:12 pm
The answer you are looking for is..... YES
Mark
MarkB
Post by MarkB » Tue Jan 02, 2007 9:13 pm
Though not 100% about the other make turbo's because theymay need to be located differently.
The S4 and RS4 share the same manifold though for K03's and K04's
Mark
Ryan_s3
Post by Ryan_s3 » Tue Jan 02, 2007 9:40 pm
not too sure how much space the turbos have on rs4's but at least i know about the manifolds.
Image360bhp 342lb/t
Golich
Re: s4/rs4 manifolds
Post by Golich » Sat Jan 06, 2007 1:59 pm
Ryan_s3 wrote:Are s4 and rs4 exhaust manifolds the same?
While I don't know for certain. I was always under the impression the RS4 manifold was slightly different as the heads are different and the RS4 doesn't suffer from the old heat sheild issue that the older S4s could.
But like I said I've no real knowledge on this only my impression.
JonnyX
Post by JonnyX » Sat Jan 06, 2007 4:36 pm
The part numbers are the same in ETKA. I have S4 and RS4 exhaust
manifolds and I can confirm they are the same. The inlet ports are different
on the RS4 - the exhaust ports are the same.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Golich
RE: Re: s4/rs4 manifolds
Post by Golich » Wed Jan 10, 2007 1:46 pm
Yes that's what it is - I thought the ports were supposed to be different from an Audiworld post from a few years back. That's good to know that an S4 is the same for the exhaust.
So I wonder if the heat shields modified around 2000? As I've never heard of an RS suffering the expensive S4 heat shield issue.
MarkB
Post by MarkB » Wed Jan 10, 2007 1:53 pm
It was the facelift S4 that had revised manifolds that are then fitted to the RS4 later. The heat shields on the exhaust do still rattle on the later cars but isn't expensive to fix. The RS4 exhaust is different to the S4
Mark
Users browsing this forum: No registered users and 88 guests
